Lower radiator hose
Old Feb 25, 2023 | 03:15 PM
scrappie's Avatar
Lower radiator hose
1970 442. I bought upper and lower radiator hoses from Fusicks. The top one fits good but the lower radiator hose is way off. Is this just Fusicks or can I order one from Rock auto and get a correct one minus the writing on the hose? Anybody have this issue or have a source for the correct one?
Old Feb 25, 2023 | 03:33 PM
oldoldss's Avatar
I've had to trim every lower radiator hose I've bought for this era Oldsmobile for years, no matter where I bought it.
Old Feb 25, 2023 | 04:46 PM
442Harv's Avatar
Yes, trim about 2 inches off and then bend, should be about right.
Old Feb 25, 2023 | 05:42 PM
Trophyblue442's Avatar
If you are going to try something else use dayco. Fit perfectly.
Old Feb 25, 2023 | 06:27 PM
scrappie's Avatar
Thanks I think I'm gonna
Old Feb 26, 2023 | 11:53 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
What about this place
https://www.supercarsunlimited.com/i....aspx?nid=1597
Old Feb 26, 2023 | 02:18 PM
Just trim the engine side of the hose until it fits without kinking.
Old Feb 26, 2023 | 02:37 PM
Loaded68W34's Avatar
It looks like you should be able to trim as mentioned above, but if you run out of room to trim (looks like you can only trim about 2" from the water pump side before you fun out of room in the expanded section of hose), I used these on my holiday coupe and they fit perfect with no trimming.
Inline tube radiator hoses
Old Feb 26, 2023 | 02:56 PM
scrappie's Avatar
OK thanks for that. It looks like I would have to trim too much like you said besides, I shouldn't have to be trimming a brand new hose.
Old Feb 26, 2023 | 03:28 PM
Yeah, I agree but if you look at the AC Delco upper hose it says “trim to fit” so it’s not unheard of.
Old Jun 9, 2024 | 07:05 PM
rickbmac's Avatar
My Bad
You are correct. I was attempting to install upside down. Thank you for the clarification!
moetrizh
Jun 15, 2022 07:33 PM
Dave S
Jun 11, 2021 07:56 PM
vickycar
Mar 28, 2017 02:13 PM
squirell
Aug 25, 2009 09:21 AM
harleyrules
Nov 25, 2007 07:22 PM
