Looking for Help on wheel/tire size
Old March 16th, 2009, 10:02 AM
nmtt92's Avatar
Hi all --
Newbie here, need to see if anyone's tried this wheel/tire setup before I order from Coker --
Car is a '66 Cutlass convertible with stock drums and suspension. Currently has original wheels and 215/75/14s.
Looking to keep outer diameter roughly the same and go with 15" wheels. So, it looks like a 245/60/15 tire will keep the revs/mile about the same. But, these tires need an 8" wheel, so I'd go with the repro SS1 15 x 8 with a 5" backspace.
Does anyone have experience with this combination? Will it work? Also, does anyone know if the 15 x 8 repro SS1 will work with a disc brake setup if I decide to do that later?
Thanks.
-- Jeff
nmtt92 is offline
Old March 16th, 2009, 10:15 AM
Originally Posted by nmtt92
Hi all --
Thanks.
-- Jeff
Welcome. The 8" wheels are good; 7" would probably be acceptable. The repro SSI wheels will clear the FACTORY disk brakes with the 10.75" rotors and the factory caliper brackets. All bets are off for aftermarket brake kits.
joe_padavano is offline
Napoleon Solo
Wheels and Tires
February 1st, 2012 03:42 PM
|-K|=K
September 21st, 2010 07:51 PM
CurtRod58
Wheels and Tires
August 28th, 2010 01:49 PM
littlejm3
March 2nd, 2008 06:35 AM
ss427
January 15th, 2008 07:47 AM
Quick Reply: Looking for Help on wheel/tire size
