how to remove/ install new rear wheel bearings 1970 cutlass
Old Apr 11, 2011 | 04:32 PM
g77rvd's Avatar
I have a 1970 cutlass s want to replace the rear wheel bearings can anyone explain to me how i would remove the bearings? I have the type "o" rear end. Are there any special tools needed to remove or install bearings?
thanks in advance
steve
Old Apr 11, 2011 | 04:52 PM
gearheads78's Avatar
car guy
I have seen all kinds of back woods ways but the best and correct way is with a press.
Old Apr 11, 2011 | 04:58 PM
ziff396's Avatar
I removed the axles on my 8.5 with a slide hammer. I then took them to a machine shop to have the old bearings removed and new ones pressed on. I think they charged me 30 bucks.
Old Apr 12, 2011 | 07:21 AM
A slide hammer is the best way to pull the axles, but I've done it by flipping the brake drum around, loosely installing three of the lug nuts (flat side in) and using the drum as a slide hammer. If you really have to wail on it, you can bend the drum, so using an old drum is a better idea.
Oldssupreme
Jul 31, 2014 07:58 PM
Mattia-SS
Jun 18, 2011 04:23 PM
oldzy
Drivetrain/Differentials
Sep 14, 2010 05:40 AM
Classiccarjohn
May 18, 2010 09:49 AM
nickwhite44
Jan 21, 2009 05:07 AM
