How many here with headers...
Old Sep 29, 2011 | 10:58 AM
oldzy's Avatar
... did not weld up that recessed center exh. divider? Just curious.
Also curious on any 'sound difference', as well as cons of not doing so (other than blowing out that exposed piece of gasket material if you did not cut it out beforehand). tx
Old Sep 29, 2011 | 12:58 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I never filled it, and mine still sounds like a tuna boat.
There is a definite tone difference when the crossovers are filled, and the divider is welded......but if the xovers are not filled, i don't think it's going to make a big difference 1 way or the other.
Old Sep 29, 2011 | 06:14 PM
coppercutlass's Avatar
Chevy budget Olds powered
i never welded up mine and i also never blew out the center piece of gasket i used the felpro blue header gaskets they never blew out
Old Oct 9, 2011 | 02:49 PM
Fastbrianman's Avatar
I never welded mine up, I have run them with block offs in the heads and without. I can't give you a before and after on that. It was always done with a rebuild. My gaskets only leaked when the bolts backed off.
I use the copper header gaskets now and do not have any problems. Well other than my 15 year old headers now rusting out. Time for new...
sburn9640
Jan 26, 2014 06:34 PM
Wyze
Mar 18, 2012 01:59 PM
auto_editor
Vista Cruiser & Wagons
Apr 10, 2011 09:21 AM
IZAOLDS
Aug 2, 2010 08:39 AM
Nailhead 88
Feb 16, 2009 07:57 PM
