High Torque Starter w/ Hooker Headers - 350
Old Aug 20, 2015 | 03:46 PM
Grant1424's Avatar
I have a 1972 Convertible Cutlass with the original 350 motor. I bought a set of Hooker headers a while back and have yet to install them. I wanted to know which brand and model of a high torque starter would be the best fit for this configuration as far as clearance and reliability goes. I do plan on wrapping the starter with heat wrap as well.
Old Aug 20, 2015 | 05:47 PM
wr1970's Avatar
I use powermaster 9510 with my hooker headers. Mine is a big block don't know if that makes a difference or not.
Old Aug 20, 2015 | 06:34 PM
Oldsmaniac's Avatar
The mini starter is not mandatory with headers but usually helpful... You may have to shim the starter though to get the right mesh with the ring gear teeth.
Old Aug 20, 2015 | 06:44 PM
76olds's Avatar
Hookers under Hood
I used the Powermaster 9610 on my 76 olds 350 with hedmann headers. Fit great, nice weight saving. Didn't use heat wrap ( no issues to date with heat soak) The only thing I didn't like initially was louder cranking noise. I got use to it now sounds normal go figure.
Hope this helps
Eric
Old Aug 20, 2015 | 06:48 PM
coppercutlass's Avatar
Chevy budget Olds powered
I use a stock starter with my long tubes . No issues . I did however make a harness to quickly disconnect the starter wich makes it so easy. To shim it I use fender shims it makes it easier and you don't have to completly unbolt the starter as they can be pushed in.
Old Aug 20, 2015 | 07:32 PM
I like the mini starters just for the ease of installation, they are much lighter. You don't have to remove the starter to install stock shims, they are slotted on the ends, so only one bolt needs to come out.
Old Aug 21, 2015 | 05:11 AM
I just don't like the starter shims lol.
RAMBOW
Aug 13, 2013 05:13 PM
davepnola
Jul 7, 2011 08:53 AM
JSGD1966
Oct 14, 2008 10:25 AM
JSGD1966
Aug 27, 2008 07:46 PM
spikey0922
Jan 11, 2003 11:31 PM
