High torque starter , with headers
Any Tilton style starter would be good. Looks like you should be looking at $150 and up to around $350 for one. I had to run one due to my 7 quart oil pan I'm running. And I lucked out on one locally for sale (swap meet) that ran $70. cash.
Scot
Scot
Powermaster,Tilton,IMI. Prices vary depending on the output,size,weight,etc. I run the IMI.My previous mini-starter was a CVR,but the problem I had was that it would not extend the gear all the way across the ring gear teeth,causing it to jump back,then slam forward with a loud bang.This is the one that Summit also sells unde their name.
http://www.robbmcperformance.com/pro...s_starter.html
Another option but high dollar. Can also be clocked in any position.
