Help with my 1965 Olds F85 1 barrel carb leaking
Old Dec 19, 2025 | 02:49 PM
d0gegarcia's Avatar
Hi Everyone, Any ideas on what I should do to fix the leaking carb on my 1965 Olds F85 deluxe? I changed the mechanical fuel pump after the car starting dying during 20 to 30 mile drives. It fixed that problem but now the 1 barrel carb is leaking out of the gaskets. This is a refurbished carb I bought from Rock Auto about 5 years ago and didn't start leaking until after I changed the fuel pump. It almost seems like the fuel pump is pumping too much gas to the carb? I replaced all the gaskets but it still leaks. I am not that mechanically inclined and really haven't had many problems with the car until now. Please let me know your thoughts. I am thinking of replacing the carb with a new one but wonder if there is a less expensive fix. Thanks.
Old Dec 19, 2025 | 05:08 PM
What brand fuel pump did you install? Many people have had Carter pumps that have too high pressure. High fuel pressure could push the needle valve off the seat, overfill the float bowl, and cause fuel to overflow.
Old Dec 20, 2025 | 06:36 AM
d0gegarcia's Avatar
It was a trugrade from autozone. I'll replace it and see if that helps. Thanks!!
Old Dec 20, 2025 | 06:55 AM
woodie582's Avatar
Check your fuel pressure on the existing pump.
Old Dec 20, 2025 | 12:47 PM
Yes, check the fuel pressure before changing the pump.
Old Dec 20, 2025 | 12:52 PM
d0gegarcia's Avatar
will do, thanks.
jonjonbear
Apr 16, 2024 04:49 PM
ChrisH526
Oct 25, 2023 04:41 PM
john paul
Oct 20, 2012 07:41 AM
KathleenF
Jun 4, 2011 10:29 AM
72 Cutty
Nov 5, 2010 04:48 PM
