Help Installing Windshield and Back-glass Reveal Moldings
Old Jun 13, 2014 | 08:56 PM
rcdynamic88's Avatar
I have a some replacement windshield and back-glass moldings from OPGI for my 1965 Olds Cutlass. The original parts where quite dented from some previous removals and installations. I just had a window guy out to install the glass with urethane rather than the original type butyl rubber. I have all new retaining clips also from OPGI. I could use some help before I bang up my new moldings putting them on.
Where is the correct place to start? Do you install the lower edge first, then the sides, and the top edge last? The corners must slide onto the lower edge a little so that they overlap, do you put them together first and then try to snap them in piece as a unit?
Let me say that I had the lower edge and the sides on once already, on both the front and the back. However, the top edge piece(s) for either the front or back would not snap down in place. I have them all back off again now without screwing any of them up. I am hoping some of you can give me some tips to get this done without denting them all up with my rubber mallet!
Old Jun 14, 2014 | 06:55 AM
Originally Posted by rcdynamic88
Ido you put them together first and then try to snap them in piece as a unit?
^^^This. You should be able to snap them in place with the flat of your hand. Also, be sure to use seam sealer or something similar under the clips when you slide then over the weld studs to cover any scratches the clips may make in the paint.
Billb442
Body work
Mar 19, 2016 05:36 PM
edzolz
Nov 13, 2013 12:31 PM
fv64olds98
Body work
Mar 12, 2013 04:50 PM
Hawk1061
Body work
Sep 12, 2012 01:18 PM
Charlie_brown
May 7, 2009 08:29 PM
