Head Code Stamp Question
I'm trying to find out what kind of vehicle this motor came from
it is a 425
389244 D Code
Passenger Side Cylinder head has stamp on it.
D243019 L
They are 548 C heads
Thanks in advance
it is a 425
389244 D Code
D243019 L
Thanks in advance
Olds didn't use a "D" prefix for the engine unit number in 66-67. The closest I can find is a "P" in the Delta 88 and Delmont 425 models. The "L" suffix means a low compression (9.0:1) 2bbl motor.
Of course, this just means that one HEAD came off such a motor. There's know way to know for sure where the block and other head came from...
it has not been disassembled before i tore it down. they are the original heads to the motor.
still has original rod/main bearings with minimal wear. From the looks of that and the lack of taper in the cylinders 100k tops mileage wise, probably less.
Thank you for the information provided so far and keep up the great work guys
According to the 67 CSM a Toro 425 should have a prefix "R" and a suffix "T"... The 66 CSM shows the Toro 425 with a suffix "T", but was not specific on the prefix... As well, I could not find a "D" code listed...
Thank you all for the information. I like how active this forum is. If anyone needs anything i have a lot of computer skills and i work on eurocars for a living. feel free to shoot me a pm if you need help or have questions.
