Hardware Packages for Restoration
Hello all,
Where would be the best place to buy hardware stacks for restoring my 71 442? I am currently looking for all hardware related to the frame (i.e. front and rear control arm, sway bar, shocks, etc... mounting), but will eventually need hardware for most everything else. Does any vendor sell complete OEM style hardware packages?
Whenever I need hardware I just run to the hardware store. Since your 442 is exactly the same as a Chevelle you might be able to get a kit of bolts, nuts, etc. from Year One.
https://www.yearone.com/
Fusick or Kanter carry Olds specific hardware like control arm bushings, sway bar bushings, shocks, etc.
https://www.fusickautomotiveproducts.com/
https://www.kanter.com/index.aspx
Also, don't forget RockAuto or your local auto parts store for parts. It's often better to purchase suspension parts individually over buying a kit because the kits are often 100% Chinesium.
AMK products may have what you need also.
http://amkproducts.com/
Those are Marantz resto hardware references. In most cases an A body is an A body and a lot of the fasteners are the same between makes. A frame kit from Chevy, Buick or Pontiac is probably the same as an Olds.
71murder
Suspension & Handling
23
August 27th, 2021 01:31 PM
ah64pilot
September 1st, 2012 08:51 AM
