Hardlines For Quadrajet Question? (Electric choke)
Old January 28th, 2018, 01:39 PM
Bowtie-Bri's Avatar
I have a question regarding the two hard lines on the pass side of the carb that go into the intake. They fit into holes somewhat loosely in a plate thats bolted to the intake. I'm worried about vac. leaks in those areas. What do you guys do to make them fit or seal into the intake?
Bowtie-Bri is offline
Old January 28th, 2018, 03:54 PM
Those lines are a fresh air intake anyway. If you follow them all the way up to the back of the carb air horn, you see that the line is completely open to ambient air pressure anyway. The issue is sucking in dust, not a vacuum leak. Usually the factory lines are a tight slip fit into the hot air stove in the crossover.
joe_padavano is offline
Old January 28th, 2018, 04:52 PM
Bowtie-Bri's Avatar
Thanks Joe!
HonestDave
July 11th, 2014 07:47 PM
beepac
January 9th, 2014 04:39 PM
mp71conv
January 21st, 2009 02:28 PM
woodie582
November 7th, 2008 01:07 PM
justinj
November 5th, 2008 06:07 PM
Quick Reply: Hardlines For Quadrajet Question? (Electric choke)
