Gas Reading
![Angry](https://classicoldsmobile.com/forums/images/icons/icon8.gif)
Hello experts. Having fuel gauge issues and I was wondering if anyone had a trick to estimate how much gas is in the tank from the pour spout, i.e. running a hanger into the tank and see how wet the hanger tip is.
Car: 1970 Cutlass S
Car: 1970 Cutlass S
These fuel gauges were never that accurate. The only 2 absolutes were fully full or almost completely empty, anything in between was a guestimate. The sending unit sensor is 0-90 ohms based on the level of the arm.
Better solution, fill the tank. Drive a 50 miles. Refill the tank. Drive another 50 miles, repeat as necessary.
Unless you have a massive fuel leak, the above method will almost certainly ensure you never run out of gas.
Or fix the fuel gauge.
illumined
August 7th, 2014 07:21 PM
