Gas tank leak
Old Jul 19, 2018 | 07:17 PM
Bmoskal's Avatar
Gas tank leak
I think I have a gas tank leak, earlier I was replacing the coil springs and shocks on driver side. When I jacked the car up further I realized some dripping, stopped and smelled the puddles contents and turned out to be gas. Never had a puddle underneath the car before and since fuel gauge don't work I have no way of telling how much gas in the tank.
could I have tilted the car to much? Or somehow did something by jacking it up so high?.
Old Jul 20, 2018 | 03:10 AM
1970cs's Avatar
Lansing built
I had to back track your prior posts to find what we are working on! 1972 supreme.
Given the tilt to that side I guess that your breather is deteriorated. Mine did that when the tank was filled during cold weather and then when there was a big upswing in the temps. it would leak sitting flat due to expansion.
I bought a new setup from Fusick. No more issues with leaking gas.
Pat
Old Jul 20, 2018 | 06:10 AM
Just went thru this, my 71 Cutlass had a gas smell at rear of car though never actually dripped on ground. I found the little rubber hoses which were original, were deteriorated and found after getting tank out that the fuel sender was loose where tube goes thru it. I changed gas lines and sender( which was only $42.00 shipped, happily) and no more gas odor.
alburk
Jan 28, 2016 09:43 AM
stratoblues
Jul 9, 2014 03:41 AM
1PDQ55
Jul 27, 2011 09:06 PM
al714
Jan 15, 2010 08:11 PM
cutlass47
Aug 26, 2008 05:00 AM
