Gas Reading
Old May 15, 2021 | 05:10 PM
wherlehy's Avatar
Angry Gas Reading
Hello experts. Having fuel gauge issues and I was wondering if anyone had a trick to estimate how much gas is in the tank from the pour spout, i.e. running a hanger into the tank and see how wet the hanger tip is.
Car: 1970 Cutlass S
Old May 15, 2021 | 07:27 PM
These fuel gauges were never that accurate. The only 2 absolutes were fully full or almost completely empty, anything in between was a guestimate. The sending unit sensor is 0-90 ohms based on the level of the arm.
Old May 16, 2021 | 01:00 AM
Ozzie's Avatar
I don't know a hanger trick. I'd probably try to repair the gauge. They may not be perfect, but are "reasonable" after calibration.
Old May 16, 2021 | 05:33 AM
Better solution, fill the tank. Drive a 50 miles. Refill the tank. Drive another 50 miles, repeat as necessary.
Unless you have a massive fuel leak, the above method will almost certainly ensure you never run out of gas.
Or fix the fuel gauge.
Bmoskal
Jul 20, 2018 06:10 AM
alburk
Jan 28, 2016 09:43 AM
illumined
Aug 7, 2014 07:21 PM
mryoung4815
Jun 16, 2010 05:54 PM
al714
Jan 15, 2010 08:11 PM
