front fender to radiator support
Old August 8th, 2010, 03:34 PM
toro455's Avatar
Location: Issaquah, Washington ( 15 miles east of Seattle )
I'm trying to remember how the front fenders fit to the radiator support on my 1970 442. I feel like a dummy and I'm second guessing myself.
Here's the problem, The radiator support has three bolt holes on each side to attach to each fender ( top of support ). I can't find a good diagram in the manual that illustrates the correct way to attach the fenders to the radiator support. The fenders seem to want to attach with the first bolt hole inside the fender and the second and third bolt holes on the outside of the fender.
I just came back from a local car show and looked at an older Cutlass that had the fenders attached the way I described above. I know that the 67' Cutlass is a little different with the radiator support and fender mounting but can anyone tell me if that is correct. The first mounting hole goes inside the fender and the second and third mounting holes on the outside of the fender ?
Maybe someone can tell me what page I missed in the manual to find the diagram for mounting the fenders. HELP !
toro455 is offline
Old August 8th, 2010, 03:46 PM
toro455's Avatar
If someone has a photo of this area of the car and is willing to post it that would be great.
toro455 is offline
Old August 8th, 2010, 05:34 PM
70 cutlass s's Avatar
The fender also mounts to the back side of the core support with two bolts to the inside of the fender.
I just start with one bolt in the cowl and one to the support. Then put the other ones in. Leaving them loose putting shims in when needed. Tighten when I get the alignment right.
Its easier to install the fender with the inner fender already attached to it.
70 cutlass s is offline
Old August 8th, 2010, 06:50 PM
Registered
Bluevista's Avatar
This is for a '71 if it helps any.
Bluevista is offline
Old August 9th, 2010, 06:26 PM
O's_Car's Avatar
Is this what you're looking for? These are pictures of my '70 Cutlass S before I took it apart.
O's_Car is offline
Old August 9th, 2010, 09:11 PM
toro455's Avatar
I thought I posted a response to your photographs Oskar but I see it didn't show up. Thank you for sharing your photos ! That was exactly what I needed.
toro455 is offline
Old August 10th, 2010, 08:57 PM
O's_Car's Avatar
No problem, glad I could help.
I have a friend that moved to Issaquah a few years ago. I think he likes it there better than Wichita...
O's_Car is offline
The Flash
September 16th, 2014 03:16 PM
wmlewis
January 13th, 2014 09:49 PM
Tom442
August 26th, 2012 05:20 PM
crazy'boutOlds
May 18th, 2012 06:30 AM
helm42
May 31st, 2011 06:43 PM
Quick Reply: front fender to radiator support
