Front Disc Brake Conversion Kit
Dad and son have a "new" 1956 88 Super Holiday 2dr. Want to change out front shoe brakes with a kit from Kanter. OK, but does anyone know if there is a kit that includes a 2 chamber master cylinder, power booster and proportioning valve? HELP! '56 pedal goes thru the floor. '61 thru the fire wall. Has anyone tried a '61 Suspended Pedal on a '56?
My two scanty pieces of information:
1. If you're a hot rodder, you can put the pedal in there any way you want with enough ingenuity and welding, otherwise, I don't think it would turn out well.
2. I know for certain that there are under-floor power brake / dual master units for older FoMoCo's, so it should be possible to either find one purpose-built for your car, or to adapt one that isn't.
No one makes a conversion for the under floor power brake booster to a dual master cylinder and there is not enough room for a hotrod underfloor conversion because of the rear steering box. You will need to install an after market booster and dual master cylinder on the firewall and a hanging pedal from a donner car. Did not know Kanter had a conversion for a 56. Take a look at this conversion http://www.scarebird.com/ to make sure your getting the right parts
I did this conversion on my 57 which is very similar to yours. Another member on site did the same conversion on his 56. Do a search and you will find him. His running thread is all 56's check in. He goes byhialeah and you can find him in the Vintage Olds forum
Mocephus
October 1st, 2021 09:45 AM
crazycowboyny
April 29th, 2014 02:33 PM
yeahbuddy
February 12th, 2014 07:14 PM
