frame numbers
Old Jun 3, 2014 | 06:35 PM
firefrost gold's Avatar
frame numbers
can any one tell me what this means ?
trying to get photo to load grrrr
Old Jun 3, 2014 | 06:58 PM
"The Anderson Tapes" is a 1971 crime / thriller movie starring Sean Connery.
imdb
Wikipedia
Never heard of it before, but it looks good.
Why do you ask?
edit: Now totally baffled as to how you posted a Russian YouTube video about a 1970s movie instead of your picture.
Old Jun 3, 2014 | 06:59 PM
Frame number behind the wheel
39443331 s in a O 193
5 19 N 1 XK
Old Jun 4, 2014 | 04:50 AM
got it to work was looking for frame Vin thought it was this but not is the one up front on side or top of frame ? Mine is undercoated so it is not easy to spot.
Old Jun 4, 2014 | 06:39 AM
ROCKET VAPOR's Avatar
Lance
IIRC, 39443331 is the part number for the frame. Your frame was manufactured by A. O. Smith with a date code of May 19. "XK" may be the broadcast code, check your assembly manual to verify this.
Old Jun 4, 2014 | 03:09 PM
BlackGold's Avatar
39443331 = Frame Assembly Number (the frame is an assembly of multiple parts).
S in a circle = Maunfactured by A.O. Smith
193 = uknown, but see below
5 19 = Date of manufacturer: May 19
N 1 = possibly a shift indicator, first shift?
XK = Applicaiton code (or like, RocketVapor called it, broadcast code)
I can't find it, but I vaguely recall a discussion on regarding the last three digits on the top line. As I recall, they incremented as the model year progressed. It's probably a lot number or something.
If you found this stamping behind the rear wheel to be in good condition, there's a good chance you'll be able to find a VIN derivative stamp as well. On my Lansing-built '70, it is on the outboard side of the left frame rail, 12 inches forward of the back of the door.
Old Jun 6, 2014 | 11:50 AM
Thanks I was thinking it was on the top of the frame . The hole thing was under coated from what I was told long before the 80's even so you could be right on finding it .
TripDeuces
Jul 12, 2019 05:15 PM
1969goatman
Aug 30, 2010 07:44 PM
dan1s
Tech Editor's Desk
Sep 10, 2009 05:28 AM
DJMatthews
Dec 5, 2006 01:28 PM
