Flathead running hot
Old Aug 27, 2021 | 05:40 AM
Bigfrank49's Avatar
I have a 1940 olds with a 230 flathead. After driving for a bit tge temp gradually starts to climb up past 210/220 . I have an aluminum radiator with a 16" electric fan. Changed thermostat flushed system and checked circulation ibeven did a chemical test to check head gasket. Any thoughts would be appreciated.
Old Aug 27, 2021 | 07:10 AM
rocketraider's Avatar
Oldsdruid
What provoked installing the aluminum radiator and electric fan in the first place?
Make sure that fan is rotating correctly so it pushes air thru radiator if it's mounted between grille and radiator, or pulling if mounted between radiator and engine.
Also make sure it's properly sized for airflow. They're not all created equal. Ford Windstar and Lincoln Mark 8 fans will get the job done, assuming the car has been rewired for 12v.
Old Aug 27, 2021 | 07:35 AM
Charlie Jones's Avatar
Phantom Phixer
I've seen the same problem in Pontiac flatheads too .
It was caused by the water distribution tube being rusted out .
The water distribution tube is made of sheetmetal , and is inside the block behind the water pump .
The tube is supposed to direct water toward the exhaust valve seats .
When they rust out , it upsets the water flow , causing " hot spots ' .
They can be removed by removing the water pump and radiator . They are usually a b*tch to pull out of the block .
They are available on E-Bay ;
1937-1950 OLDSMOBILE 6 CYLINDER NEW OLD STOCK WATER DISTRIBUTION TUBE | eBay
Old Aug 28, 2021 | 12:14 PM
Funkwagon455's Avatar
I will second this valid theory. The previous owner of my ‘40 eight made it clear to me that he’d replaced the tube in my car and emphasized the importance.
Billyboy746
Jul 5, 2020 08:11 AM
huskerala
Jun 26, 2018 09:31 AM
rhodyrocket2
Jul 18, 2017 01:44 AM
spyke
Mar 10, 2014 06:08 AM
68Tom
Apr 28, 2009 05:22 PM
