fenders / dash pad question
Old August 9th, 2014 | 09:16 AM
drew1987gn's Avatar
Hi to all. I have the opportunity to purchase a 70 442 and I found a few things that I question and need some help. First, the owner (not the original owner) is telling me he believes the fenders are original however on the inside lip there are the raised ribs telling me otherwise. Is it possible that the fenders can be indeed original depending on when and where the car was built? It is not a Lansing built car. Second, the car has no a/c however the dash pad has the side and center vents for a/c, but no duct work under the dash. Is this also possible with a non a/c car to have this dash pad? Any and all feedback is greatly appreciated. Thanks, Andy.
Old August 9th, 2014 | 09:36 AM
72notchback's Avatar
Looking for 71-72 Cutlass
The dash pads are the same for ac and non ac. The difference is the center will be actual working vents on an ac car, and not the blanked version. The lack of ducts leads me to believe the dash might have been at least taken out at one point.
Also, those side ducts are the rectangular shaped ones and the most difficult and expensive of all the under dash ductwork. I was lucky enough to pick some up off of a member here.
Old August 9th, 2014 | 09:44 AM
drew1987gn's Avatar
That makes sense. The center blank is exactly what the car has. The only duct work I can see under the dash is for the defrost and for the heat. I was concerned that someone took the whole a/c components out. Thanks for the response!!
Old August 10th, 2014 | 11:45 AM
No. The seller is incorrect. More likely the car had the front end replaced after an accident.
Jimi2much
August 5th, 2014 08:05 PM
6inarow
December 8th, 2010 06:59 AM
Bryan59EC
June 3rd, 2010 10:36 AM
floater98
May 27th, 2010 03:45 AM
DJMatthews
December 12th, 2006 06:36 AM
Quick Reply: fenders / dash pad question
