Fan shroud
Old Feb 1, 2019 | 05:29 PM
Fan shroud
Anyone in readerland have detailed pics of how the shroud is suppose to mount to the core support? Mine has never fit well. It’s kinda hard to tell from the factory manuals. I’d like to use the cold winter to get whatever is needed to make it fit correctly. Thanks!
i guess I forgot to mention it for my 69. I’m running a Be-Cool radiator with the top pate modified to fit the wider tanks
Old Feb 1, 2019 | 06:43 PM
2blu442's Avatar
Matt, is this for your 1969? Does it have the 2 or 3 row radiator top plate or the 4 row one? Some cars came factory without a shroud, and for the 1968-72 years I know there was a different top plate. Then I know the 70-72 had tabs attached to the bottom of the core support that were not there on the non-shroud application. I'm sharing all this to say its possible someone changed what's there and you may not have the correct parts to get the fit you want. I'll try to come up with some photos for you. If you have time to post pictures of what you have, how the top plate looks and how the shroud is attached at the top and bottom that might also help members here spot any problems you may have. John
Old Feb 1, 2019 | 06:59 PM
2blu442's Avatar
Matt, here's a diagram. I can still try and get photos of any areas that are unclear to you. John
Old Feb 2, 2019 | 04:20 AM
It’s for my 69. After looking over those illustrations, im wondering if it’s the correct shroud I made my own lower brackets, I have never been very happy with how things fit.
Old Feb 2, 2019 | 09:39 AM
2blu442's Avatar
Matt, when you take things apart look over the shroud real well. There should be both a part number, I think 6 digits long, and then a two digit date code inside a starburst.
Old Feb 2, 2019 | 05:47 PM
Where should I look for the part number/date code?
Old Feb 2, 2019 | 07:14 PM
2blu442's Avatar
Matt, if its not the original shroud I don't know where it would be. But if its like most I've seen you'll be able to spot it pretty easily.
John
Old Feb 3, 2019 | 03:51 AM
Fpcopo's Avatar
Interesting in that the sheet shows W30 and W31 didn’t use a shroud
matt69olds
Apr 13, 2020 07:45 AM
kevdog442
Mar 19, 2018 06:28 PM
dfire25
Oct 14, 2013 03:34 PM
70Cutlass_408
Jun 28, 2011 05:23 PM
Bunser
Apr 30, 2010 10:20 AM
