Factory Distributor Weights and Springs
Since there obviously are no distinguishing markings on factory distributor springs, is there any way to determine their original application if separated from the distributor?
With no part number on factory distributor weights, is it possible to determine their original application?
The factory weight can be weighed to determine if it matches the weight for a particular application, but factory weights seem to have different thicknesses and edges according to the model year, as well as some having holes in the weight.
Aftermarket distributor advance kits do not note the tension and weight of the springs and weights contained in the kit.
Hoping to find OEM or equivalent springs and weights for a 1970 350 4bbl distributor that is missing the factory weights and springs. According to the parts book, the factory spring is 1942012 and the weight is 1881371.
Have you turned the weights over and looked at the bottom sides? My weights have numbers stamped into them.
edit:
After re-reading you may be referring to points distributors and I was thinking HEI.
edit:
I couldn't find a good picture.
71OldscutlassS
August 24th, 2021 09:55 AM
