Exhaust manifold Assembly
Old Sep 7, 2020 | 07:09 PM
servexcell's Avatar
Is there a reference in the Assemly manuel in 68 and 69 for Exhaust manifold installation. I was unable to find a refernce
thanks Bruce
Old Sep 7, 2020 | 07:22 PM
What specifically are you looking for? I’m sure there is a torque spec, along with the usual clearance and other checks.
Old Sep 7, 2020 | 07:24 PM
servexcell's Avatar
i was looking for part no and size of bolts and hardware. Also torque spec
i was unable to find it.
thanks
Old Sep 8, 2020 | 05:14 AM
The torque spec is in the torque table at the end of chapter 6B in the CSM.
Old Sep 8, 2020 | 07:06 AM
Noel Anderson's Avatar
https://pacificgbody.com/blogs/shop/...s-in-one-place
Old Sep 8, 2020 | 10:44 AM
servexcell's Avatar
thanks Joe and Noel . is there a reference or picture of part no. and are the tabs reguired
thanks
Old Sep 8, 2020 | 10:47 AM
The tabs are just locks to prevent the bolts from loosening up. I hate them. I personally never reinstall them. I'd rather just check the bolt torque periodically.
Old Sep 8, 2020 | 11:05 AM
servexcell's Avatar
Do they prevent the bolts from getting loose
servexcell's Avatar
i am very surprised there is no refernce in Assemby Manuel
Old Sep 8, 2020 | 11:40 AM
https://www.ebay.com/itm/1979-Trans-...72.m2749.l2649
Should work on all small block Oldsmobile, these are stainless steel, Inline also sell steel ones for less.
Old Sep 8, 2020 | 11:55 AM
From my previous post:
The PIM (Assembly Manual) encompasses the assembly operations performed on the assembly line. The manifolds come already bolted to the engine. You need the engine assembly manual for that information. The PIM doesn't have any info on how to assemble the transmission or rear axle, either.
Old Sep 8, 2020 | 02:44 PM
servexcell's Avatar
Joe where can i find that manual ?
thanks
Old Sep 8, 2020 | 04:36 PM
I have one for 1969 that I got as part of the PIM reprints sold by Paul Sigmund. They are few and far between. I have not seen a 68 engine assembly manual.
Old Sep 8, 2020 | 05:09 PM
servexcell's Avatar
Joe would you be able to send the the page for exhaust manifolds
thanks Bruce
Old Sep 8, 2020 | 05:21 PM
servexcell's Avatar
I just looked through my 69 Assembly Manuel and found a pink section all related to engine. I purchased this also through Paul Sigmund . Thanks for the help.
Bruce
tru-blue 442
Mar 26, 2015 07:02 PM
FTolliver
Mar 28, 2014 08:12 AM
hurstoldsgal
Aug 19, 2011 10:32 AM
D Appeldorn
Dec 31, 2009 02:40 AM
oldsracer
Sep 1, 2009 03:24 AM
