Engine accessories strap
Old May 30, 2023 | 12:59 PM
keyboard's Avatar
Hi guys.
I am trying to locate the accessory strap.
Right now you have a Goodyear 11AV1460, 15581 installed, however, I cannot locate it in my country.
Do you know of another compatible model?
It seems that this Goodyear is no longer manufactured.
Thank you.
Regards
Old May 30, 2023 | 01:50 PM
I @$$ume your car is a 68-72 Cutlass with air conditioning. If so, get a Gates 7445 belt to replace that one.
Old May 30, 2023 | 02:27 PM
Goodyear 15581 is readily available in the US for under USD$6. It's a 58.07" (1474.98 mm) outside circumference V-belt. effective length is 57.5". That should let you find a comparable belt locally.
Equivalent belts are:
Dayco 15575
Pirelli 13-575 (13-580 should also work)
Continental 15581
Old May 30, 2023 | 02:30 PM
keyboard's Avatar
Hi sir.
It is an olds 1971 442, it has air conditioning.
I can't find the one you recommended in my area either
Any other suggestions?
Thanks.
Old May 30, 2023 | 02:39 PM
Originally Posted by keyboard
Hi sir.
Thanks.
Give me a minute....I "may" have a replacement belt. Hang on.
Old May 30, 2023 | 02:45 PM
I'm going to need to dig up (research) if this brand new belt I have is compatible/appropriate for your installation. I'll puke up the Part No. in case Joe has this number stashed in the back of his cerebrum and knows specifically if it's of the correct length, etc.
DAYCO Top Cog
Part No. 15450 (11A1145)
Old May 30, 2023 | 02:47 PM
I guess it's a no-go. Says it's 45"L. Sorry.
Old May 30, 2023 | 03:02 PM
Your replacement belt is presumably for an SBO. Taller deck height means longer belts for alternator and A/C.
Old May 30, 2023 | 03:26 PM
I believe you're correct. I purchased an extra for my 350 w/ A/C. I only knew I had an extra new belt. Thanks.
Old May 31, 2023 | 01:08 PM
keyboard's Avatar
Goodyear 15581 está disponible en los EE. UU. por menos de USD $6. Es una correa en V de circunferencia exterior de 58,07" (1474,98 mm). La longitud efectiva es de 57,5". Eso debería permitirle encontrar un cinturón comparable localmente.
Los cinturones equivalentes son:
Dayco 15575
Pirelli 13-575 (13-580 también debería funcionar)
Continental 15581
Thanks Joe, I have located the Continental, size is 1450mm, should work but I am going to try.
If I have problem I will let you know.
Thanks for the help guys!!
skyhigh
Apr 10, 2023 07:38 PM
mileggarmy
Dec 12, 2022 06:00 AM
ericisback
Oct 21, 2021 06:20 AM
420weblazeit
Apr 7, 2014 10:12 AM
captjim
Jul 15, 2009 08:53 AM
