cruise control servo rod
Does anyone know what the difference is between a 2 barrel and a 4 barrel cruise control servo rod. I think one is longer but i have a couple and they are the same length but have different bends in them, so im not sure. Assembly manual says the ends have different colors but that is long gone on these i have. Does anyone have one to see or sell?
Thanks W31man
Thanks W31man
Here is a picture of the linkage, however you cannot see the bend.
The bend is not too much and is 1.5" from the carb linkage end.
The 2bbl one is 1" longer than the 4bbl but it would work for a 4bbl. At most you would have to cut off a little and possibly add a few extra threads to it (std 1/4 - 20).
Let me know if you need a picture when on the car...
cruise servo rod
Thanks for the info, you would think there would be at least 1 inch of adjustment in those rods that they wouldnt need two different ones. I saw the note in the manual i was just curious.
gregc
September 16th, 2010 06:16 AM
