Crankshaft repair
Crankshaft repair
Crankshaft have k nicks in it... That I can kind grab tip of finger nail on....any recommendations on how this would mess my engine up...Any quit fix tips on this also ????
400 is a very fine grit and I don't think it would know down much of a burr but I don't think it would hurt. For what is at risk I would still take it to a machinist and get an expert opinion.
Is the nick on a main journal or on a rod journal ? How did the crank get a nick ? A nick is caused by impact of something hard or sharp. How did the bearings look ? You don't get nicks by rotating the engine without priming the oiling system. Was lube applied when assembling ?
My concern is........are there anymore nicks that haven't been discovered yet.
A very fine stone can knock down the nick, if done carefully.
This can work in a very localized spot BUT ....... if you dont know what you are doing you will only make it worse. It will have to be polished afterwards anyway so just take it to your machine shop and let them take care of it.
How the nick was discovered and how the nick got there has me curious. I am concerned that there might be other nicks that haven't been discovered yet.
A crankshaft trip to a good machine shop is seeming more likely.
