Correct Steering Column Cover_1968 Olds Cutlass S
Old July 25th, 2017, 06:01 PM
1968 Olds Cutlass S
jdana24's Avatar
I am replacing the lower steering column cover and have purchased the SCC682 item from Fusick (see first photo). However, when I went to install it, the cover is different than what is in my car. So I went into the Assembly Manual and saw that the one I purchased looks completely different than the one I took out of my car and the one they show in the manual which is in the second photo. Has anyone else purchased this item from Fusick for their 1968 Olds. I can't imagine that they would still be selling a part if it is not correct for the application. Or is the one in my car and the Assembly manual not correct?
jdana24 is offline
Old July 25th, 2017, 07:01 PM
2blu442's Avatar
I'm not a 1968 expert, but I'd bet the Chassis Service Manual is correct and Fusick goofed.
2blu442 is offline
Old July 26th, 2017, 04:07 AM
rob1960's Avatar
The one you have is '68 only. Unfortunately a lot of the repo parts get grouped into the '68-'72 category. The parts place also shows the same one Fusick has. I have an Ames(GTO) catalog & they don't list one for '68 at all. They show 64-67 & 69-72. I have a Nov 67 Lansing built 442 & the carpet guard that's in mine looks just like the one in the service manual pic. Maybe later '68s got the newer,longer one???
rob1960 is offline
Old July 26th, 2017, 07:28 AM
oldspackrat's Avatar
I might have a '68 version if you can stand by for a day or two while I check.
oldspackrat is offline
Old July 27th, 2017, 01:01 PM
Randy C.
rcorrigan5's Avatar
Doesn't look like the right one to me! I've run into this with a few other things as well. For the most part, though, Fusick is good. I'm sure they will take the cover back as a return, and possibly correct their catalog as well!
Randy C.
rcorrigan5 is online now
Old July 28th, 2017, 09:01 PM
1968 Olds Cutlass S
jdana24's Avatar
John, you were right. Fusick has the wrong part for 1968. Rob, I've checked all of the places you checked and none of them carry a part for 1968. And Randy you were right, Steve said to send it back and he will give me a credit to use on my next order. My column cover has a crack right down the middle which I have used a Loctite plastic gel super glue to repair, but if I can find a used on that is in good condition it would be nice to have one that isn't cracked, even though you can't see it without getting on the floor.
And thanks Scott for offering to check to see if you have one for 1968.
jdana24 is offline
Old July 28th, 2017, 09:44 PM
I believe I located a nice one today, my only one like this. Not sure how/if Photobucket will work anymore so I'd rather text pictures to you? Text me with "toe kick" at 317-727-7041. $40.00 shipped and I'm pretty certain you won't be disappointed.
Old July 29th, 2017, 09:13 AM
1968 Olds Cutlass S
jdana24's Avatar
Just sent you a text.
Thanks, Jeff
jdana24 is offline
starfire
December 9th, 2021 08:21 PM
6884rocket
October 29th, 2016 05:16 PM
317Cutty
June 18th, 2014 10:53 AM
oddball
March 4th, 2014 06:42 AM
Al Graaf
April 10th, 2012 02:57 PM
Quick Reply: Correct Steering Column Cover_1968 Olds Cutlass S
