Convertible Top Question
Old Aug 6, 2018 | 02:10 PM
Cutlassfarmer's Avatar
I just bought a 1970 Cutlass convertible. When the top is in the down position when you use the switch to put the top in the up position it requires help getting the top to move. Does not seem to catch on anything, frame seems in good condition. When it is about a 25% open it seems to move on its own. No change in the sound coming from top motor when it is not going up on its own. Slowly completely closes. Seem to work fine from up position to the cdown position. You can stop it about 1/2 going up and down and it holds. So is it the motor, fluid level, cylinders. Nothing seems to be leaking. Just looking for ideas to pinpoint the problem
Old Aug 6, 2018 | 05:14 PM
It's low on fluid. Top it off and it will work properly.
Old Aug 6, 2018 | 06:32 PM
Thanks for the reply. That is what my first guess would be. Like I said I just got this car a week ago. I bought it from an older gentleman that decided to sell it. It only has 65K miles on it. He had it serviced at a local repair shop for everything. How do I know what fluid is currently in it? I have read on this forum about different types of fluids being used?
thanks again for the tip
Old Aug 6, 2018 | 08:39 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It should be ATF and will be red. You do not want to use brake fluid because it will eat your paint if it gets on it.
Old Aug 6, 2018 | 11:46 PM
Gary M's Avatar
Also if it's low on fluid, it went somewhere. Take the back seat side panels off if there is no oil present in the pump area and look for oil around the cylinders on either side. If you see a lot replace one or both cylinders and or hoses because if one springs a big leak it will ruin your top if it sprays up on it. .(so I've heard).
Old Aug 7, 2018 | 07:13 PM
Took the back seat out and checked the fluid level. Added about 6 oz of transmission fluid and top raised on it own. Ran it up and down a few times. Cylinders looked good and lines dry. Took longer to remove seats than fill the pump.
Thanks again for for the advice
Old Aug 7, 2018 | 11:00 PM
Gary M's Avatar
Yes it was more work but now you know you don't have to worry about your top or buying cylinders at 100.00 each. Congratulations most times they are bad. You got lucky. Enjoy you new ride.
Bfg
Sep 16, 2018 03:51 PM
Rocketbrian
Jun 27, 2017 04:11 PM
kbdecatur
Aug 23, 2012 03:49 PM
kens69olds
Jul 19, 2011 09:22 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
