convertible top motor
Old May 3, 2012 | 06:14 AM
kbdecatur's Avatar
Hello im tring to find out how can i find out if i need a top switch or if the top motor is bad its a 72 cutlass..
Old May 3, 2012 | 06:46 AM
Lady72nRob71's Avatar
Will jiggling the switch or mashing it harder cause any partial operation of the top (or at least some kind of sound from back there?
If so, switch is bad.
If not, check circuit breaker in fuse block, top left corner (metal can) . Verify 12V on both sides when measured to ground while mashing the top switch in either direction.
Next, jump 12V to the large purple and / or large gray wires coming from the switch. Do this at whatever connector you can get at, either under the dash or behind the rear seat.
However, make sure the motor ground wire is attached and secure first.
For reference, here is what the switch looks like from behind the dash (right-side picture)...
Orange is constant 12V.
The motor has two independent windings for up and down so chances are it should work in at least one direction. I vote main power or switch. In 72 the switch moves all the current to the motor (no relays) so the contacts usually burn and pit, causing failure.
Instructions for getting the switch out and overhauling it can be found here:
https://classicoldsmobile.com/forums...html#post58161
Old May 3, 2012 | 01:12 PM
kbdecatur's Avatar
convertible top
Thanks for the information this is very helpful...
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
fmbjogger
Feb 6, 2011 03:13 PM
MDchanic
Oct 2, 2010 07:17 PM
1969goatman
Sep 8, 2010 02:08 PM
bittersweet71
Dec 9, 2009 09:21 AM
