Convertible header bow
Old February 5th, 2011 | 02:11 PM
kitfoxdave's Avatar
Is the 72 cutlass header bow the same as a 72 chevelle header bow?
(mine showers me with rust every time the top goes up or down
Thanks for your help!
Old February 5th, 2011 | 02:15 PM
Yup. Whole darn thing's identical.
Old February 5th, 2011 | 02:16 PM
kitfoxdave's Avatar
Great Info! Thanks a bunch!
Old February 5th, 2011 | 02:21 PM
oldsconv's Avatar
Yes. 68-72 A body is same (Cutlass, Chevelle, GTO, etc.). Repros are $400 but you might be able to find a decent one used - alot of them are rusted - I guess moisture gets trapped there. Paul Toller sells a lot of used parts - ROS6872Parts.com. I was looking for something cheap needing a little work and he had a decent one requiring two small patches (and I have a welder, so it was easy). He probably also has nicer ones for more money - nice guy to deal with.
Thanks, Pete
Old February 5th, 2011 | 03:06 PM
When I did mine, I ground down the small rust holes and fiberglassed it, then POR'd the whole thing.
Worked great.
As long as the structure isn't compromised and your repair is smooth (can't be seen through the top material), you're good to go.
70convert
August 22nd, 2013 06:37 AM
68 cutty
May 29th, 2013 11:42 PM
zippy
July 29th, 2012 05:41 PM
1001coins
March 21st, 2011 06:30 PM
pitfield1
February 16th, 2011 06:39 PM
