Convertible header bow
Old Feb 5, 2011 | 01:11 PM
kitfoxdave's Avatar
Is the 72 cutlass header bow the same as a 72 chevelle header bow?
(mine showers me with rust every time the top goes up or down
Thanks for your help!
Old Feb 5, 2011 | 01:15 PM
Yup. Whole darn thing's identical.
Old Feb 5, 2011 | 01:16 PM
kitfoxdave's Avatar
Great Info! Thanks a bunch!
Old Feb 5, 2011 | 01:21 PM
oldsconv's Avatar
Yes. 68-72 A body is same (Cutlass, Chevelle, GTO, etc.). Repros are $400 but you might be able to find a decent one used - alot of them are rusted - I guess moisture gets trapped there. Paul Toller sells a lot of used parts - ROS6872Parts.com. I was looking for something cheap needing a little work and he had a decent one requiring two small patches (and I have a welder, so it was easy). He probably also has nicer ones for more money - nice guy to deal with.
Thanks, Pete
Old Feb 5, 2011 | 02:06 PM
When I did mine, I ground down the small rust holes and fiberglassed it, then POR'd the whole thing.
Worked great.
As long as the structure isn't compromised and your repair is smooth (can't be seen through the top material), you're good to go.
70convert
Aug 22, 2013 05:37 AM
68 cutty
May 29, 2013 10:42 PM
zippy
Jul 29, 2012 04:41 PM
1001coins
Mar 21, 2011 05:30 PM
pitfield1
Feb 16, 2011 05:39 PM
