Convertible Frame Repair
Old Jun 20, 2009 | 09:45 AM
Southern_Hospitality's Avatar
I have a 71 Olds Cutlass Conv't. I need to know if a convertible frame can be repaired? Where the top intially connects to the frame, that portion is slightly eaten by rust. All advise is good advise. Thanks.
Old Jun 20, 2009 | 10:07 AM
csstrux's Avatar
need pics to tell. They are worth a thousand words you know.
Old Jun 20, 2009 | 01:00 PM
Originally Posted by Southern_Hospitality
Where the top intially connects to the frame...
Unfortunately, that's not terribly descriptive. If you are talking about the header bow, which is the frontmost lateral crossmember in the top frame, the one that sits on top of the windshield frame, rust there is common. Reproduction header bows are available (Chevelle is the same as your Cutlass) and it is a bolt-on part.
Old Jun 20, 2009 | 06:42 PM
68conv455's Avatar
If it is slight rust. You can patch it just like you would the body. If it is more than that, Joe has the answer above. I've see them for $400.
Old Jun 25, 2009 | 08:22 AM
FOUND IT!
ok guys, i think joe was right. its the header bow. thanks.
oldspackrat
Jul 20, 2022 07:34 AM
fiebs442
Jan 11, 2015 07:05 PM
oldspackrat
Dec 21, 2012 08:27 PM
oldsmobilty
Sep 27, 2012 04:26 PM
