Carburetor
Old Mar 25, 2018 | 04:59 PM
FTolliver's Avatar
Carburetor
Good evening, I have a question for you. I have a 1961 Dynamic 88, 394, 2 barrel, carb. Iam going to upgrade to a 4barrel. What is recommended? I know work has to be done to make an Edelbrock function properly. I have a stock 4 barrel intake.
Old Mar 25, 2018 | 05:49 PM
Tedd Thompson's Avatar
The easiest would be a Rochester 4gc, that's what they came with.If you can get the carb linkage for the 4 bbl the swap would be even quicker. .... Tedd
Old Mar 25, 2018 | 06:10 PM
FTolliver's Avatar
Thank you.
Old Mar 26, 2018 | 01:19 AM
shiftbyear's Avatar
Although Tedd is correct, I like the latest design from Edelbrock AVS2 series, with electric choke and 2 cfm options, it seems like a good carb. I'm a Quadrajet lover, but the on your application the Edelbrock would be my first choice. Good luck with your conversion.
http://www.edelbrock.com/automotive/...ors/avs2.shtml
Old Mar 26, 2018 | 05:06 AM
FTolliver's Avatar
Carb. thoughts
Thank you.
Old Mar 26, 2018 | 05:54 AM
Doesn't your Dynamic 88 have the Slim Jim Rotohydramatic transmission in it? If so switching to an aftermarket carb will be rather difficult. You would have to make sure the manual throttle valve lever was setup correctly. That transmission does NOT tolerate misadjustment. Be careful!
Old Apr 1, 2018 | 09:13 AM
FTolliver's Avatar
Thank you. I will try and not mess this up.
Old Apr 2, 2018 | 02:02 AM
Ozzie's Avatar
If you've got the Hydramatic, the easiest approach would be the Rochester 4GC and the original 4GC linkage, unless you are really good at linkage fabrication. If you have the 1961 Oldsmobile service manual and would like to see what is involved, look on pages 3-73 through 3-76. It's nothing for a novice to tackle. Even with the original linkage, sometime it's a challenge to get that Hydramatic to shift properly.
Old Apr 2, 2018 | 07:07 AM
FTolliver's Avatar
carbureator
I do have the shop manual as well as the chiltons. I will read up on this before i dive in. Thank you.
yeahbuddy
Jun 1, 2010 05:38 AM
Gaz Hog
Oct 17, 2007 07:26 AM
TheRuss
Jul 25, 2007 01:22 PM
olds307owner
May 23, 2007 09:01 AM
ViceGuy
Mar 25, 2007 01:43 PM
