A/C Delete Blower Resistor
Old Jul 20, 2025 | 11:24 AM
eh70's Avatar
Deleting the A/C on my 1970 Cutlass Supreme. Have already rebuilt the original AC box and installed with an aftermarket AC delete cover on the firewall side. I have a new blower relay. Trying to figure out which blower resistor I would need (AC vs Non-AC) and where that would get mounted. I have a CSM but it doesn't specify for my situation.
Any help would be appreciated. Thanks.
Old Jul 20, 2025 | 11:27 AM
cfair's Avatar
In my ‘66’s the key question is whether your heater switch has 3 positions (for the heater only system) or 4 positions (for the heater +AC system).
If it were me and my dash switch had 4 speed settings, I’d use the 4 pin AC resistor block, just to match the switch.
Chris
Old Jul 20, 2025 | 06:15 PM
Despite the delete cover, you still have to use the A/C control head because of the vacuum-operated flapper doors in the under-dash box. This control head has four fan speeds (non-A/C control heads only have three fan speeds). You must use the resistor that matches the control head, which is the A/C resistor.
Old Jul 21, 2025 | 05:31 AM
eh70's Avatar
Makes sense. As always, thanks Joe.
Loucobalt
Feb 23, 2020 01:11 PM
Kallin Kurtz
Feb 9, 2017 09:47 AM
W-27
Jul 23, 2015 07:55 AM
gpseven
Jun 21, 2015 08:08 AM
devmar07
Dec 20, 2011 11:53 AM
