Bucket seat removal
Old Nov 11, 2021 | 01:29 PM
wherlehy's Avatar
Bucket seat removal
Hello my friends,
1970 Cutlass S - bucket seats with console.
i need to remove the rear seats to install a new luggage shelf. I am 6'-2", 230 lb (not my hockey playing weight... lol) and need to remove the front two bucket seats to give my belly some room. Also I want to do some vent work under the dash... and need the room.
Question 1: do the studs in the floor stay when I remove the top nut of the bucket seat mounts?
Question 2: Is there any tips I should know doing this - like the seat belts need to be removed first?
Question 3: Any tips I should know removing the back seats or installing the new luggage shelf?
Thank you - you experts have help me so much restoring this gem!
Bill
Old Nov 11, 2021 | 01:48 PM
Yes the studs are mounted to the floor. The nuts come off. That's it.
I don't believe you need to remove the seat belts.
Rear seat you push in on the seat bottom. Both sides. Back of the seat is bolted in. The bolts are accessable once the bottom is removed. Remove those bolts and it slides up. There are two slots that the back slides into.
Old Nov 11, 2021 | 03:11 PM
Seat belts can stay.
One thing I found is it's better to remove the front two seat track fasteners, then slide the seat to remove the tension on the spring. Then when rear fasteners are removed the seat track doesn't try to retract on you.
Old Nov 11, 2021 | 03:21 PM
RetroRanger's Avatar
72 Olds CS
Nice 70
i really like the green the white top and stripes look smart as well
Old Nov 11, 2021 | 03:23 PM
wherlehy's Avatar
Nice tip - thank you!
wherlehy's Avatar
Thank you sir - unfortunately I have to sell it - daughter needs $$ and family comes first!
Old Nov 11, 2021 | 04:08 PM
Nice 70
Agreed green looks so good on Oldsmobiles.
Old Nov 12, 2021 | 05:55 AM
72 Olds CS
Where are you located?
Old Nov 12, 2021 | 06:00 AM
wherlehy's Avatar
Plano, TX
Old Nov 12, 2021 | 06:23 PM
72 Olds CS
Too bad im in mass
fab4fan2004
Nov 10, 2020 01:18 PM
ttwiebe
Jan 29, 2015 11:39 AM
BeenThere
May 25, 2014 04:35 AM
76_cutty
Aug 10, 2013 06:45 PM
firefighter5174
Feb 23, 2013 02:54 PM
