Assembly Manual / screw sizes
Old Apr 30, 2019 | 09:21 AM
70convert's Avatar
Does anybody know if there is a list of actual sizes for the screws, bolts etc that are referenced by numbers in the assembly manual.
Old Apr 30, 2019 | 10:30 AM
I'll have another look at my ASM, but in 'general' what I have found is each bolt, nut & screw is identified by a Part Number in the ASM. I don't believe I've examined the ASM to determine if there is a listing of Part Numbers which detail each items dimensions.
Old Apr 30, 2019 | 10:45 AM
Well, I have a CD case marked as Oldsmobile Parts Manual with Wiring Diagrams (1965 - 1975) but there is no CD in the case - which means I must have either lost it or it is misplaced. I was hoping it might provide more detail regarding nuts, bolts & screws part numbers and there actual dimensions. Sorry. Perhaps another CO member might be able to help you out.
Old Apr 30, 2019 | 11:11 AM
rcorrigan5's Avatar
Randy C.
I've had some luck cross-referencing the part numbers in the assembly manual to the AMK Products catalog. On some other fasteners I've been able to match them to a fastener in the AMK Products catalog by the picture in the catalog against what I have. I have an old catalog (about 10 years old) that I use but I do believe you can research the on-line catalog at amkproducts.com.
Randy C.
Old Apr 30, 2019 | 11:36 AM
70convert's Avatar
Thanks everybody
Vintage Chief have you checked the frig for the CD
Old Apr 30, 2019 | 11:55 AM
Thanks everybody
Anything is possible!
Old Apr 30, 2019 | 01:49 PM
BeenThere's Avatar
A GM Standard Parts Catalog has the information you need.
scrappie
Feb 7, 2018 06:56 AM
Cincinnati Rick
Jan 15, 2015 02:31 PM
CUT-N-UP
Nov 6, 2013 07:10 PM
Al Graaf
Apr 3, 2012 05:52 AM
stevengerard
May 6, 2010 10:47 AM
