Antenna change
You can get away with removing all the lower and side bolts and pulling the fender back and holding it back with a block of wood. However, pull it back just enough to get your arm up there. Pull back too much and the fender will deform, and not match the curves of the door.
Long sleeves are highly recommended.
The mid-80s Cutlii had a unique inner fender arrangement that was part metal and part plastic. Also, tons of crap is bolted to the inners. It was easier on that to pull the fender back.
