Antenna change
Old Oct 17, 2011 | 01:43 AM
footbrake455's Avatar
Antenna change
Need to replace the antenna on my 85 cutlass supreme. It's a power one. what kind of a job is this gonna be? Looks like I have to take off the fender.
Old Oct 17, 2011 | 05:34 AM
Lady72nRob71's Avatar
You can get away with removing all the lower and side bolts and pulling the fender back and holding it back with a block of wood. However, pull it back just enough to get your arm up there. Pull back too much and the fender will deform, and not match the curves of the door.
Long sleeves are highly recommended.
Old Oct 17, 2011 | 05:50 AM
69HO43's Avatar
Here's a link that may help:
http://tech.oldsgmail.com/echa_antenna.php
Old Dec 7, 2011 | 09:58 AM
Redog's Avatar
I wonder if you could just remove the plastic sheild inside the fender and drop the power anetnna that way?
I'm replacing with a fixed OEM antenna
Old Dec 7, 2011 | 10:27 AM
If you have a plastic inner that is easily removable - go for it.
The mid-80s Cutlii had a unique inner fender arrangement that was part metal and part plastic. Also, tons of crap is bolted to the inners. It was easier on that to pull the fender back.
Old Dec 8, 2011 | 10:38 AM
Redog's Avatar
^^ Yeah I felt it real quick yesterday. I felt plastic and metal, but didn't see a seam
I did it quick cause it was raining like crazy yesterday
curtis mayfield
Feb 21, 2023 07:13 AM
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
dan1s
May 5, 2008 08:05 AM
JoshF85
May 25, 2005 08:14 PM
