Another Questions (Exhaust)
Okay guys, I have another question. I'm looking at just replacing my exhaust system all together, especially after the negatives I've seen about flow-master mufflers. Any-who, I'm looking for an idea for a good header back exhaust system, that's both cheap and easy to install. I already have hooker super comp headers that are still running strong, so I just need a system from the headers back.
Any tips would be greatly appreciated,
Thanks!
Thanks!
If you want a bolt on kit... buy the flowmaster american thunder kit w/o mufflers(you have to specifically find the listing number for teh kit w/o numbers).
Its only like $250
Then add whatever offset/offset mufflers you like and away you go.
Its by far one of the best fitting kits out there w/o having the goofy X-pipe sounds.
Its only like $250
Thanks for the tips guys. Does anyone know anything about the Summit Racing exhaust kits? Are they any good?
I've got this car all jacked up, the weathers nice and I've got a bad case of the might-as-wells
I have heard pypes exhaust is good. I made my own exhaust with an x pipe from summit with bolt on mufflers i set up for track removal with hooker aero chambers and dumps at the rear end sounds good. You can also order just the pipes from pypes exhauts individally and add your own muffler i belive but some phone calling might be in order to do so .
You cannot truely get an idea what stuff sounds like from reading postings online, or even listing to 30 second sound clips of cars.
there are a ton of factors that will affect the way any given cars exhaust will sound.
A car with a certain style pipes & mufflers may sound totally different on another car with its engine setup differently, or different mufflers. Even just changing the brand of headers can affect the sound.
I had it installed on my car w/ a mild Chev 350 and man it sounded terrible Like it had a v6 in it.... after a couple months i hacked it off the car and had them weld it back up with straight pipes- sounded like a v8 again.
Like i said... _ _ _ component on one guys car may not sound the same on YOUR car.
not intending to high jack. but does anybody know if the flowmaster kit or the kit from summit racing will exit in the correct location for the cut-out bumper with a 455. thanks And does anyone like the sound of the provided mufflers? pros cons? just be nice to know what you guys like about other mufflers over these.
Thanks!
Thanks!
coldwar
February 20th, 2014 01:09 AM
