76 delta 88 charc canister
hello,
so on my 76 delta 88 there was a electric fuel pump ran so i was wondering should i add an regulator with return line back to fuel tank and add a vented gas cap
or should i re due the evap and hook the canister back up and if so does it has to have a purge valve and if so where does the line from the canister go to the intake or the carb?
