Hooking up Charcoal canister 76 delta 88
How many ports are on the charcoal canister?
On my '77 Toro, there are two ports. The smaller-diameter one closer to the front of the car connects to a manifold vacuum port on the carburetor. The larger-diameter port connects to a metal line mounted on the inner fender that I presume leads back to the gas tank. I don't know that yours is the same. If you have a '76 service manual, all of this is covered in detail in the fuel system section (most likely section 6C2) with detailed hose diagrams for the canister for every Olds model.
