Hooking up Charcoal canister 76 delta 88
Old May 6, 2021 | 12:27 PM
Keonj229's Avatar
My charcoal canister was never hooked up on my 76 delta 88 since purchasing any info how to hook up ???
my fuel pump has 3 ports
Old May 6, 2021 | 01:09 PM
jaunty75's Avatar
How many ports are on the charcoal canister?
On my '77 Toro, there are two ports. The smaller-diameter one closer to the front of the car connects to a manifold vacuum port on the carburetor. The larger-diameter port connects to a metal line mounted on the inner fender that I presume leads back to the gas tank. I don't know that yours is the same. If you have a '76 service manual, all of this is covered in detail in the fuel system section (most likely section 6C2) with detailed hose diagrams for the canister for every Olds model.
Old May 6, 2021 | 01:20 PM
Keonj229's Avatar
thanks for the info I’ll see if I can find the diagram online
Keonj229
Apr 28, 2021 01:28 PM
Keonj229
Apr 26, 2021 04:56 AM
Keonj229
Apr 22, 2021 03:49 AM
Dboi78
Cars Wanted
Jan 25, 2018 11:49 AM
old45dude
Jun 8, 2010 03:10 PM
