71 W27 Cover
Old Mar 1, 2019 | 08:39 AM
friesjh's Avatar
71 W27 Cover
Hello all,
I've been reading as much as I can about the W27 rear ends and covers, but it looks like most everything I've read refers to the 12 bolt W27. The 71 I got last year came with a W27 cover, which was an option in 71. How do I tell if its OEM or repro? I'll get some pictures today after work and post them.
Old Mar 1, 2019 | 10:49 AM
friesjh's Avatar
Thanks Joe! I'll get pictures later today.If the cover is not OEM it was most likely purchased in the late 80's.
Old Mar 2, 2019 | 08:09 AM
W27 covers were an option in 1971, and they have a 10 bolt pattern. So 2 different covers - 12 bolt and 10 bolt.
Old Mar 4, 2019 | 06:13 AM
friesjh's Avatar
Here are a couple of pictures. Please let me know if OEM, decent reproduction, or bad reproduction. I have read that there is a special gasket for the 12 bolt version. Are the 10 bolts the same? If so, does anyone have the p/n and/or where I can buy this gasket? Also, are the mounting bolts specific to the W27 cover or are the mounting bolts for the standard cover the same? If different can you let me know what I'm looking for on the bolts?
Old Mar 6, 2019 | 07:39 AM
70cutty's Avatar
Beer Connoisseur
You don't need a gasket. I used Black RTV and no issues, that's exactly what they used in the shop that assembled the rear differential. 2 shops that I use for my rear axles never use gaskets, I gave them one that came in the kit and they said they prefer silicone. As far as the mounting bolts, regular cover bolts will not work as they are too short. You need 5/16-18, 1" long. I used ARP black oxide cause I like the contrast. ARP-651-1000
Mikeb23
Aug 11, 2017 06:13 AM
Sarum
Drivetrain/Differentials
Oct 13, 2014 01:45 AM
Vader
Jun 11, 2014 01:19 PM
Vader
Jan 5, 2014 04:39 PM
RALLYE KID
May 5, 2013 05:50 AM
