'70 4 speed rubber PCV elbow need
I've gone through a couple different PCV elbows - the one from the 4-speed intake manifold nipple to the PCV valve is what I'm referring to... As soon as they get a little fuel or oil on them they swell and don't fit any longer. I haven't seen an NOS one for a long time, and I haven't found a repro that works well. Are there any good suppliers of this part or any substitutions that anyone is using successfully?
This elbow - to the right of the PCV valve.
Bob---I would reach out to Jim Michaels from Classic Olds in Clemmons, NC and he can help you. He just sold me mine for the resto I completed and it works great on my stock W-30 intake. Tell him Dave from CO sent you his way.
You can google 442 W30 PCV ELBOW, there are a few vendors.
https://www.google.com/search?q=442+...w=1366&bih=625
My tractor has a similar ish 90 degree hose for a trans cooler. Its super common for them them to blow out or leak after a few short years of use.
there is a retrofit kit to replace the 90* parts w steel tube. I tried some other than OEM hose there and it was in poor shape in less time.
the point of my long winded tangental reply is the 90* tractor hose ( made for hot oil) if a correct fit is likely a better quality hose than the repro part your using.
ill see if i can find a link to that hose part.
https://www.ebay.com/itm/17451374668...QAAOSwc2pfqwxy
here it is, if i can find one off the tractor ill measure it
I lold at the one written feedback on it. It does carry hot hydro oil.
Fits fine. Just wish it would last longer than 3 years
