'70 4 speed rubber PCV elbow need
Old Sep 9, 2021 | 05:37 AM
BSiegPaint's Avatar
I've gone through a couple different PCV elbows - the one from the 4-speed intake manifold nipple to the PCV valve is what I'm referring to... As soon as they get a little fuel or oil on them they swell and don't fit any longer. I haven't seen an NOS one for a long time, and I haven't found a repro that works well. Are there any good suppliers of this part or any substitutions that anyone is using successfully?
This elbow - to the right of the PCV valve.
Old Sep 9, 2021 | 08:30 AM
442Dude's Avatar
Bob---I would reach out to Jim Michaels from Classic Olds in Clemmons, NC and he can help you. He just sold me mine for the resto I completed and it works great on my stock W-30 intake. Tell him Dave from CO sent you his way.
Old Sep 9, 2021 | 02:54 PM
BSiegPaint's Avatar
Thank you! I got his number and will call
Old Sep 14, 2021 | 11:33 AM
shiftbyear's Avatar
You can google 442 W30 PCV ELBOW, there are a few vendors.
https://www.google.com/search?q=442+...w=1366&bih=625
Old Sep 14, 2021 | 11:59 AM
BSiegPaint's Avatar
Each one of those vendors seems to use the same supplier, as I've gone through several of them. It seriously just takes a few days before the snug fit isn't anymore, and within a week you have oil blowing out around the edges onto your manifold. I've found an NOS one for my final restoration use, but for now, I'm curious if anyone has found something that works well for them, or if everyone is just letting them leak....!
Old Sep 14, 2021 | 12:57 PM
RetroRanger's Avatar
72 Olds CS
My tractor has a similar ish 90 degree hose for a trans cooler. Its super common for them them to blow out or leak after a few short years of use.
there is a retrofit kit to replace the 90* parts w steel tube. I tried some other than OEM hose there and it was in poor shape in less time.
the point of my long winded tangental reply is the 90* tractor hose ( made for hot oil) if a correct fit is likely a better quality hose than the repro part your using.
ill see if i can find a link to that hose part.
Old Sep 14, 2021 | 01:03 PM
72 Olds CS
https://www.ebay.com/itm/17451374668...QAAOSwc2pfqwxy
here it is, if i can find one off the tractor ill measure it
I lold at the one written feedback on it. It does carry hot hydro oil.
Fits fine. Just wish it would last longer than 3 years
Old Sep 16, 2021 | 07:09 PM
BSiegPaint's Avatar
Thank you! - ordered it. I'd say they are a bit picky at 3 years lol!!!
Old Sep 23, 2021 | 09:45 AM
72 Olds CS
Hi Bob
i just came across this in my tractor spares. I measured the id and od in case any one else sees this.
the bag says made in usa and the hose says neoprene
hth
dean
oldsmoboogie
Jun 15, 2014 07:17 AM
tinner
Jun 9, 2013 05:47 PM
timothypaul
May 11, 2013 12:04 PM
apachemobile
Feb 5, 2010 04:59 PM
65cutty
Feb 24, 2009 05:18 AM
