69 Olds 442 Thermostatic Vac Switch Routing
Old Dec 10, 2019 | 08:53 AM
tmd442's Avatar
69 442 w/AC and a 4 speed,
I looked through the Chassis Manual as well as the Assembly manual and It doesn't make sense to me.
My TVS has the top port routed to the Air Cleaner, The Middle Port is routed to the front of the intake manifold and the bottom port only has a short piece of hose on it with a small orifice at the end.
The car does run very well and has not overheated at idle.
Should I leave well enough alone?
Old Dec 10, 2019 | 11:06 AM
I would leave it as is unless you want the underhood to be "show correct".
Old Dec 10, 2019 | 11:45 AM
tmd442's Avatar
Then I'll leave it as is.
Not interested in show correct .
Old Dec 10, 2019 | 04:20 PM
Trophyblue442's Avatar
Here is the correct routing for a 69 w/ ac and 4 speed.
Top (blue) to vacuum advance
middle (red) to carb
bottom (yellow) to intake.
Old Dec 10, 2019 | 06:01 PM
tmd442's Avatar
Great info and thanks for the picture very helpful.
Where on the island are you from?
I originally lived n Huntington prior to relocating to Florida..
Thanks again.
One more question
Currently the upper TVS vacuum lines goes to the item pictured.
Where would that be connected to if I follow the correct routing?
Thank you
Gaz Hog
Jun 4, 2015 03:03 PM
rvandeven
Aug 11, 2014 10:41 AM
leit
Jul 15, 2014 09:47 AM
dnmfranco
Dec 6, 2013 08:11 PM
pogo69
Hurst/Olds
Apr 3, 2011 11:03 AM
