68 442 floor shift column issue
Old Dec 12, 2021 | 08:39 AM
KCastl03's Avatar
Took the old signal switch out and installed the new one but can’t get the screws to draw in on the column with the new switch in place. Anyone run into this problem? Any good solutions or instructions? I appreciate it!
Old Dec 12, 2021 | 09:59 AM
442Harv's Avatar
Did you strip the screw holes? If so, I would try a little larger screw. Also if striped, you can try packing fine steal wool in the hole and may grab, worth a try,
Old Dec 12, 2021 | 03:20 PM
oldolds88's Avatar
did you pull the wire harness down thru the column before you tightened the screws?
Old Dec 12, 2021 | 03:29 PM
Pull the turn signal switch up out of the way temporarily. Thread each screw into the hole in the column housing. Does it tighten up? If so, your problem is that you don't have the switch all the way into place. If not, you've managed to strip the threads.
Old Dec 12, 2021 | 03:48 PM
KCastl03's Avatar
Perfect. Thanks guys! I’ll try both options. Goal is to take it for its maiden voyage before Christmas for a present to myself and this was a big sticking point in getting there.
shamusj
Apr 27, 2021 05:45 AM
toymobile
Sep 13, 2018 05:42 AM
toymobile
Jun 18, 2018 05:50 AM
allyolds68
Jan 28, 2016 08:21 AM
chrisneu68olds
Jun 29, 2015 02:53 PM
