68 442 floor shift column issue
Took the old signal switch out and installed the new one but can’t get the screws to draw in on the column with the new switch in place. Anyone run into this problem? Any good solutions or instructions? I appreciate it!
Pull the turn signal switch up out of the way temporarily. Thread each screw into the hole in the column housing. Does it tighten up? If so, your problem is that you don't have the switch all the way into place. If not, you've managed to strip the threads.
chrisneu68olds
Jun 29, 2015 02:53 PM
