65 442 motor rebuild
Old May 15, 2016 | 07:50 AM
Bfg's Avatar
Bfg
Hi all, just a few questions about the rebuild! I have the motor all torn down from what was just being a regasket. Turned out to be the might as well job! I'm at the point of replacing the rod and main bearings even though the originals don't look bad. The Pistons and rings don't appear to be bad either. Am I wrong to just hone the cylinders and reuse the same rings or is this half assed?
Old May 15, 2016 | 08:00 AM
I would replace the rings since your there already, its not that expensive. I would also send the heads out to a respected machine shop that knows Oldsmobiles to have them gone through and replace the valve guide seals. I would also inspect the cam and lifters and if there is any sign of wear replace them also. Also replace the timing set, remove the oil pump pickup, and clean all the plastic bits from the screen. Also inspect/ replace the freeze plugs.
Old May 15, 2016 | 11:34 AM
2blu442's Avatar
Since you've got it dismantled to this point I'd have everything inspected. Also check for taper on the cylinders before deciding between honing and boring.
John
ros6872
Feb 4, 2016 05:51 AM
jensenracing77
Jan 12, 2016 02:02 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
