330 #3 heads valley pan gasket
Old Jun 29, 2012 | 04:48 PM
a64olz's Avatar
How about the correct 1966 330 #3 head part number for the valley pan gasket, the Victor Reinz #MS15925 sure aint the one, this has the locator holes top side my 330 are below the ports this is the second wrong gasket I have got. The first one the bozos gave me a beuwick. I am guessing again Fel-pro 96009? I need a frosty adult beverage.
Old Jun 30, 2012 | 06:50 AM
That would be the pn for the valley pan, there is also a 4 peice steel shim gasket that fits your car if it has a small tray bolted in the lifter galley, MS9947-1, I like this one.
Old Jun 30, 2012 | 10:23 AM
a64olz's Avatar
Thanks, I am using an Edelbrock intake so the stock pan is not an option.
Old Jun 30, 2012 | 11:35 AM
Then I would use a Mr Gasket or Felpro, fiber high performance gasket.
Old Jul 2, 2012 | 08:42 PM
Texas69's Avatar
Educate me...
Why can't the stock pan gasket be used with an Edelbrock intake? I've seen this refered to elsewhere. Just trying to learn here.
Old Jul 3, 2012 | 04:41 AM
a64olz's Avatar
The stock valley pan or tray on 330's up to mid 1967 is a steel pan that is bolted to the lifter galley and is not part of the intake gasket. The Edelbrock intake manifold will not clear the raised ends of the steel pan.
Old Jul 3, 2012 | 06:32 AM
Zactly, I know of people who use the 4 piece shim gasket set with an aluminum intake, however with the unlike metals and uneven cooling and heating I prefer a fiber gasket.
tgilligan
Jan 29, 2014 05:47 PM
getitmann
May 25, 2012 08:40 PM
defiant1
Mar 14, 2011 04:26 PM
ddx77
Jun 14, 2010 07:37 AM
Flye
May 12, 2009 05:30 PM
