2002 Intrigue 3.5 head gaskets any advise on changing them.
Old Mar 23, 2017 | 10:43 AM
lemoldsnut's Avatar
Has anyone done a set of head gaskets on one of these? If so what issues am I in for? I am very mechanically inclined and have done head gaskets before. Any specific issues related to this application?
Old Mar 23, 2017 | 10:55 AM
Support the engine under the oil pan with a floor jack before disconnecting the motor mount. This will allow you to rock the engine forward to remove the rear head.
Old Mar 23, 2017 | 11:13 AM
B964's Avatar
It books for about 18 hours to do both. Cam holder tool, torque angle meter needed. New head bolts also.
Old Mar 23, 2017 | 11:25 AM
CRUZN 66's Avatar
Olds Fever
Since the 3.5 is a mini version of the 4.6 Northstar, as a precaution, in addition to changing the head bolts, I would recommend drilling the block and adding new head bolt inserts (aka Time-sert)... This is almost a necessity when changing head gaskets on the 4.6, I don't know for fact this is a real issue with the 3.5, but I would hate to find there is an issue after the job is done... JMO
http://www.timesert.com/html/gm.html
Olds24
Aug 29, 2013 08:32 PM
Tedd Thompson
Apr 8, 2013 05:41 PM
lemoldsnut
Dec 16, 2012 09:26 AM
Luckyme1870
Aurora
Jul 26, 2007 05:05 AM
Iron Chef Ajax
Intrigue
Aug 7, 2006 08:36 AM
